Multiple sent message copies: Odd (see below)
There is a single e-mail address to which I send messages with some frequency.  It's a gmail address.  When I send the message, I wind up with between 2 and 10 partial messages (prior to when I finish composing) in the sent folder, with the park flag enabled.  The final message also is in the sent directory, without the park flag.  I have many other gmail addresses to which I send messages where this does not happen.  It's just this one address.  And, it happens every time.  Outlook IMAP account.
It's annoying.
Any thoughts?
Thanks.
Lurk your filters. May be you have in some of them "parking" condition.
A quick way to disable filters is in Account -> Properties -> Mail management -> IMAP Fine-Tune: select "Do not use filters".
A possible workaround: Options -> Preferences -> Viewer/Editor: increase Auto-save time.
It's not filters.  Will try the autosave time mod.
But, why with just a single e-mail address.  This never happens otherwise.
Yeah, it is a bit bizarre. If it were universal, I'd suspect connection problems with the IMAP server, or something to that effect.
Come to think of it, there could be some external process interfering, like antispam/malware on your machine or on the server side, not liking that address for some reason. And having a bad interaction with autosave.
Edited: Miloš Radovanović - 23 August 2026 00:13:41
Miloš Radovanović wrote:
[..] I'd suspect connection problems with the IMAP server, or something to that effect.
My guess would be a folder mapping conflict between Gmail and The Bat, involving the Drafts folder (Outbox).
Yeah, Account -> Properties -> Mail management. TB often does not assign them automatically.
